Hello DJ´s
Yesterday i bought a 5.1 Sound card for mi PC, it is a Genius PCI sound card.
I installed it whitout problems, but when i configurated my Virtual DJ in the mode of 4.1 channels: master output-rear and haedphones-front. I listened both tracks in the master channel (rear channel) what happened??? The front channel (headphones) worked well, but in the master channel i could heard both tracks!!!!
HOW CAN I REPAIR IT??? O CONFIGURATE MY VIRTUAL DJ???
Please help me!!!
Please help me!!!
Posted Tue 03 Jun 08 @ 5:16 pm
Hello DJ Gamez,
You should check there is no 3D virtualisation effect loaded in your sound card control panel: I don't know your Genius PCI Card, but in general if you hear a reverb of another stereo output somewhere, it is generally coming form a 3D positionning effect you should disable.
Posted Sun 08 Jun 08 @ 11:31 am
Hello Made In Breizh thanks for your answer!
I already checked the 3D effect in my integrated sound card, but this was disable. And in the another sound card (5.1 card) didn´t have this option.
What ca i do???
What ca i do???
Posted Sun 08 Jun 08 @ 4:08 pm
