HAVE A COUPLE THINGS TO CHAT ABOUT.
1. THE VIRTUAL DJ THAT COMES WITH THE RMX SUCKS. I HAVE VDJ 3.4 FOR THE MK2 AND IT IS 10X BETTER THAN 5.1 THAT COMES WITH THE RMX. IS THERE ANY WAY TO STILL USE 3.4 WITH MY NEW RMX? PLEASE SOMEONE LET ME KNOW. EVEN THE PRO EDITION IS NO GOOD WIT THE RMX.
2. THE RMX LOOK AND FEEL IS BETTER. BUT IT TAKES A WHOLE LOT OF POWER FROM MY USB DRIVE. YOU CAN BUY A POWERED USB HUB TO FIX THE PROBLEM BUT THE MK2 NEEDS TO BE HOOKED UP DIRECTLY TO THE USB OR IT WILL NOT WORK. (AT LEAST IT DIDN'T ON MY COMPUTER)
3. ALSO SOMETIMES WITH THE MK2 MY VIRTUAL DJ WILL LOCK UP ON ME I CAN STILL USE ALL THE CONTROL BUTTONS BUT NOTHING WILL PLAY THE TRACK WON'T EVEN MOVE. THEN I HAVE TO RE START MY VDJ. ANY ANSWERS TO THAT ONE?
4. I THINK IMMA GO BACK TO MY LAST YEAR DRIVER CAUSE I DIDN'T HAVE A PROBLEM TILL I UPDATED. MAYBE THEY SPENT TOO MUCH TIME ON VISTA AND THE RMX TO EVEN WORRY ABOUT MK2.
WELL I HAVE 6 MORE DAYS BEFORE I CAN'T RETURN MY RMX SO WE WILL SEE. I WILL LET EVERYBODY KNOW HOW IT GOES.
THANKS
THANKS
Posted Thu 29 May 08 @ 8:09 pm
Hi
Turn off your Caps Lock, it looks bad on the forum (which means you are shouting ;) ).
1.You can't use RMX on old 3.4 version as it does not have support for this controller. Check if you have any updates for your 5.0 version in download center. RMX has some issues and the Team is aware of it. It will be fixed soon.
2. As with any new hardware, there is issues that have to be resolved (that's why MK2 version is much better than first one).
3.It can be anything, you should try 2007 drivers, I still use them on MK2 and they work perfect. Clean install of OS or VDJ, updating drivers would help also.
4.See number 3 ;)
4.See number 3 ;)
Posted Fri 30 May 08 @ 8:09 am
RIGHT ON DJ-ALF
YEAH I THINK I WILL RESULT BACK TO THE 2007 DRIVER. IF THAT DOESN'T WORK ON TO STEP 2
THANKS FOR THE HELP. SORRY FOR THE CAPS MINE STAYS ON AT ALL TIMES ;)
Posted Sat 31 May 08 @ 9:39 am
LOL, broken Caps lock right there ;)
Posted Sat 31 May 08 @ 9:47 am
YOU ALREADY KNOW LOL!
Posted Sat 31 May 08 @ 1:20 pm
your either an idiot or ignorant
Posted Sat 31 May 08 @ 6:32 pm
harsh, tayla, so harsh
LOL
LOL
Posted Mon 02 Jun 08 @ 10:57 am
For all you Brits .................. HELLO, I CAN'T SPEAK NOW I'M IN A LIBRARY!!! :O)
Posted Mon 02 Jun 08 @ 11:40 am
