Every so often, and twice last night in the first half hour, complete silence was coming from virtual DJ. What I had to do was to unplug the USB soundcard and plug it back in. Weird workaround, wouldn't you agree? Sound comes back.
I run a 2 gB ram shuttle with a 256MB dedicated video card and a Behringer USB (not vey expensive) sound card I am running the sound setup on "auto" latency, at fast performance.
What do ya think might be going on?
Posted Thu 22 May 08 @ 7:28 am
One word: Behringer. If it has newer drivers you might try that and update DirectX also.
Avoid Behringer gear if you can.
Posted Thu 22 May 08 @ 10:49 am
Not sure if it has specific drivers, it just the real simple 29 dollar usb device that came with the Behringer 1404FX Mixer?
Posted Fri 23 May 08 @ 8:06 am
I am not familiar with that card, can you write down exact model number to look for it online?
Posted Fri 23 May 08 @ 8:50 am
hi ive just got the demo at the mo but when ive got my headphones on no noise from the speakers on my pc
Posted Sun 25 May 08 @ 10:54 am
Apologies in advance if this sounds really stupid or obvious, although i don't know your sound card or the real reason this might happen, I have had a problem that matches your description perfectly.
My solution, ensure all usb hardware or is connected before powering up your laptop. Iv never had a problem since.
Hope you get it fixed, Enjoy!
Posted Mon 26 May 08 @ 7:22 am
I think his is Behringer UCA200 U-Control soundcard as it came with the mixer. I don't think it is available as a separate device. I have one that came with my 1832fx xenyx mixer but never use it for djing or sound till now.
@ bryantpb, u could try to update the driver at the hardware tab at the system sound panel. It could be named as USB audio device. Sorry can't be much of help.
Regards.
Posted Mon 26 May 08 @ 2:06 pm
thx, I'll try that.
Anyone else??
Anyone else??
Posted Wed 28 May 08 @ 8:48 pm
Try disabling power management on all of your USB root hubs in device manager (under "Universal Serial Bus Controllers" heading).
Posted Wed 28 May 08 @ 11:05 pm
What precisely takes effect when this is Disabled?
Posted Fri 30 May 08 @ 10:54 am
I think this means that windows will not turn the power off to hubs in order to save power they will be continuously on when a device is connected, which means that the device will not suddenly be turn off.
I've done it to my hubs.
Posted Fri 30 May 08 @ 12:27 pm
Why would they turn off to save power if you are not usimg a battery, but plugged in instead?
Posted Mon 02 Jun 08 @ 10:07 am
Because windows is crap, lol.
it does some strange things when it wants too. I would do it, just in case, it won't harm anything.
Posted Mon 02 Jun 08 @ 10:19 am
Quite simply, it keeps the power on for your USB devices.
Windows API controls this feature, and it does not have to be on battery to be active. It turns off the power to USB devices that it thinks have been idle for awhile unless you manually disable it as described, or unplug and replug it, as you have described. I think it has to do with Energy Star compliance or something - I'm not 100% sure. As Jimmy said, it won't harm anything to do, and could very well solve your issue ;)
Posted Tue 03 Jun 08 @ 2:09 am
