I know some other folk have had a similar problem in the past with this, but I cant seem to resolve it.
Have downloaded version 5.07 about 6 times now and each time when I try to run the exe i get an error message saying the file size is not correct.
I have tried downloading with both firefox and IE, have cleared the cache in both have tried right clicking the link in the download centre. I have tried to install the exe on both my desktop (XP) and laptop (Vista) but all with the same result.
Is there anything else anyone can suggest so I can upgrade?
Cheers
John
Cheers
John
Posted Wed 30 Apr 08 @ 2:14 pm
Use only IE, do not right click on the link - left click on the link. Please visit the download center and try again.
Posted Wed 30 Apr 08 @ 2:51 pm
Thanks for the help cstoll, unfortunatly, still having the same problem.
Have deleted all the temporary internet files but still no luck, am using IE version 6. should I try updating to version 7?
Cheers
John
Cheers
John
Posted Thu 01 May 08 @ 3:14 am
No it should be working fine with IE6
Have you tried from a different computer ? Once you download the file - just use a thumbdrive OR burn the exe to a CD.
Posted Thu 01 May 08 @ 5:34 am
I did try on another desktop and it has installed fine. Cheers
However when I go to run the karaoke plugin an error pops up with dsdx9_33.dll is missing, I will see if the plugin is available on the plugin page if not any suggestions?
Ta
John
ps just checked its not on the plugin page so any help would be appreciated.
Ta
John
Posted Thu 01 May 08 @ 7:53 am
Google dsdx9_33.dll and the word download. Just replace it..see if that helps.
Posted Thu 01 May 08 @ 7:59 am
Thanks to cstoll and tearemup.
Everything going along swimmingly now.
Cheers
John
Cheers
John
Posted Thu 01 May 08 @ 10:27 am
Good to hear....
Posted Thu 01 May 08 @ 10:46 am
