Does anyone know where I can get an external power supply for my Numark DJ IO? I am clueless.
DJ Rev. James Jay
www.SubZeroSounds.com
DJ Rev. James Jay
Posted Thu 24 Apr 08 @ 4:34 pm
Wow, nobody knows?
Posted Fri 25 Apr 08 @ 11:21 am
You want Skyfxl, for this.
He is a UK Numark rep. PM him, I'm sure he could help you out.
Posted Fri 25 Apr 08 @ 11:30 am
I just bought a universal one I think it works just the same has long as it gives out de 6v it needs and the conector fits.
Posted Fri 25 Apr 08 @ 2:11 pm
Hi i see you are located in the Usa the best bet would be to order one from the US office.
You require a MP6-1 6V DC, 1.0A, Pin Positive adaptor.
http://www.numark.com/contact/
Mark your contact request for the parts department.
Posted Fri 25 Apr 08 @ 2:40 pm
Thank you!!!
Posted Fri 25 Apr 08 @ 3:05 pm
i bought one of those and plugged it in, but the dj/io power supply led does not light up so dont know if it works ?
Posted Fri 28 Jan 11 @ 2:53 pm
Have you tried using a powered USB Hub?
Posted Fri 28 Jan 11 @ 5:25 pm
looked at those, but youve still gotta hook up the DJIO to your pc anyway so dont really see the point ;)
anyone else used a 'non numark' power supply..? need to know if the led is meant to light up or not before i leave feedback on this universal 6V 1A adapter I bought !
Posted Sun 30 Jan 11 @ 7:08 pm
Sorry for posting in this old thread but, what is the advantage of using the supply with this card?
Thanks!
Thanks!
Posted Sun 29 Jan 12 @ 4:27 am
