Hi
Can anyone assist me? When I plug my DJ Mixstation 2 into my home Hi-fi using RCA cables the quality of the sound is drastically reduced and softer when compared to the sound directly from my pc speakers. Why is that so? How can I amplify the sound? Is there any good amplification software that is compatable to DJ MIxstation.
Posted Thu 23 Dec 04 @ 3:21 am
If you use cd-in or line-in and NOT phono-in, at your home hi-fi, you should not need to pre-amp the sound.
Posted Thu 23 Dec 04 @ 5:41 am
If you use a normal soundcard, this can be consider as been normal and you should have the same issue if you use a headphone.
Posted Thu 23 Dec 04 @ 10:51 am
Did you check the volume in the Windows config ?
Posted Thu 23 Dec 04 @ 12:36 pm
Even aux in or tape in will work!
Posted Sat 25 Dec 04 @ 2:51 pm
Hi,
I am DJ VDV,
I THINK THAT YOUR COMPUTERS MOTHERBOARD OR YOUR SOUND CARD NOT ENOUGH TO AMPLIFY THE MUSIC. IF, YOU HAVE ENOUGH MONEY TO YOU BUY HIGHTER PERPHOMENCE MOTHERBOARD OR SOUND CARD THAT YOU BUY IT. IF YOU HAVE NOT THAN START THE COMPUTER AND CHECK YOUR COMPUTERS SOUND AND HALF IT. OR YOUR MUSIC SYSTEM IS NOT FOR HIGHTER QULITY SOUND.
I am DJ VDV,
Posted Sun 26 Dec 04 @ 10:02 am
