I HAVE GOT MY HERCULES WORKING WITH THE SOFTWARE BUT WEN I TRY STREAM IN CHAT ROOMS I GET NO SOUND CAN SUM 1 HELP ME PLEASE...
WOULD BE MUCH APRICIATTED
Posted Sat 05 Apr 08 @ 11:30 am
How did you get your Hercules MK2 working with the software? I've tried almost everything:(
Posted Sat 05 Apr 08 @ 2:27 pm
Hi there, seem u have managed to change the traktor le version for the VDJ djc edition. Kewl;)
For ur DJC edition which is V3.4.1, u just need to plug in the controller before u start VDJ n select the mk2 in the sound settings (u can only choose a one set up, mostly are grey as the options only for Pro edition user).
IF u using the trial, go to the controller setting n select the mk2 icon n activate it.
Posted Sun 06 Apr 08 @ 3:20 pm
How are u streaming it into chat rooms? Cause im not sure that just VDJ alone can do that
Posted Sun 06 Apr 08 @ 11:40 pm
