Hi i bought a ASIO soundcard which is called: M-Audio Delta ASIO 1010LT
the card have 4 input channels and 4 output channels.
BUT 1 of the inpute channels are MICROPHONE PLUGS / CONNECTERs ! and they are unlucky the 1/2 in's, which is what VDJ use :/
Heres the question, can i change the inputs to be fx: 3/4 and 5/6 instead of 1/2 and 3/4 ? If i can, please post a reply.
Posted Thu 03 Apr 08 @ 12:53 pm
why would you want to do that. Suggestions would be read your manuel, or contact tech support for the card
Posted Thu 03 Apr 08 @ 5:34 pm
because the input: 1/2 is a microphone connecters/plugs, and a normal wifi plug (red and white) doesnt fit in a microphone connectors.
Posted Fri 04 Apr 08 @ 10:59 am
you delete the A's in the other comment, then its right !
Posted Fri 04 Apr 08 @ 11:02 am
its not the card, its your non-changeable VitualDJ !
Posted Sat 05 Apr 08 @ 11:04 am
