Can someone please guide me through the process of eliminating all inteference with other devices on the USB port which i use to connect my controller? Please!!!!! VDJ often freezes in the middle of a set and my controller doesn't respond. I then have to close and open VDJ for it work again. I'm guessing it has to do with interference from other devices on the same USB port because I've pretty much tried everything else....
Thanks a lot guys! This is urgent!
Posted Wed 26 Mar 08 @ 2:42 pm
oh, and by "other devices" I don't mean devices that are connected over a hub or such... Anyboday know what I mean?
Posted Fri 28 Mar 08 @ 6:52 am
what controler do you have?
i had a similar issue with my BDC2000. i had the the exact same issue.. it plays just fine for a while and then vdj locks up.
in my case it was caused by the bad audio-driver (in ASIO mode) of the BCD2000.
my solutions was: buy an external soundcard (like maya 44 usb or something) i still use the BCD2000 for the controls and Maya44usb for outputting audio -> no more lockups!
i think bad ASIO-drivers is your problem.
Posted Fri 04 Apr 08 @ 9:10 am
