no signal at all
Posted Wed 23 Apr 08 @ 1:06 am
MACADOCIOUS wrote :
no signal at all
Please try two things 1, ensure the power adaptor is not connected , 2 try booting your computer with the VV box already connected.
Does this improve this?
Posted Wed 23 Apr 08 @ 3:01 am
Ya, ALWAYS make sure the VV box is connected at startup otherwise it won't work.
Posted Wed 23 Apr 08 @ 5:28 am
That seems to only affect a couple of mac types but well worth a try.
Posted Wed 23 Apr 08 @ 7:06 am
You're right skyfxl, i had to configure my MAYA44 via aggregate device, now everything work, thank's for the support.
Only one thing that it seems strange, i hear the good sound when i play but the timecode quality is still remaining on 0%, is it normal?
Posted Fri 25 Apr 08 @ 3:37 pm
sometimes it plays, sometimes it doesn't
Posted Fri 25 Apr 08 @ 8:20 pm
Unfortunately it can be a bit strange like that how does the wave look?
Posted Sat 26 Apr 08 @ 5:06 am
Its funny how everyone says have the VVbox plugged in before starting the computer. I have to plug mine in after to get it to work.
Posted Sat 26 Apr 08 @ 5:54 am
unplugged power adaptor and rebooted computer with vv box and still no timecode signal
Posted Mon 28 Apr 08 @ 12:56 pm
Could you please post a shot of this config?
Posted Mon 28 Apr 08 @ 2:40 pm
using single timecode here (left side)
Posted Mon 28 Apr 08 @ 3:57 pm
I see you have a total flat line this suggests either dead cables or perhaps fauly or incorrectly installed headshell.
Does the turntable output normal records ok to your mixer?
Does the soundcard output when choosing external mixer mode?
Posted Mon 28 Apr 08 @ 4:41 pm
the turntable does output normal records just fine and the soundcard does work in the external mixer mode
Posted Mon 28 Apr 08 @ 9:22 pm
I just don't think the mac version is ready for timecode.
Posted Tue 29 Apr 08 @ 2:04 am
You havent by chance accidentally connected to the passtrough inputs? this would stop all signal from reaching the device.
Posted Tue 29 Apr 08 @ 4:24 am
this sure is weird, but it started working again. music is playing, but at times, sounds as if the music is dragging
and almost sounds like it wants to play in reverse. sounds similar to if we slow the record down by maybe placing
our fingers on the side of the platter.
Posted Tue 29 Apr 08 @ 10:14 am
music sounding weird help!!
Posted Wed 30 Apr 08 @ 10:18 am
which latency is it set to?
Posted Wed 30 Apr 08 @ 2:46 pm
fastest (1024)
Posted Wed 30 Apr 08 @ 5:28 pm
latency to auto. have u tried that?
Posted Wed 30 Apr 08 @ 5:37 pm
