just got the program and when i click on effects the letters in the boxes to change the effect(like volume and delay) dont show. neither do the words in the boxes for video effects or anything else?someone wanna explain
Posted Thu 20 Mar 08 @ 5:35 pm
Sounds like the VDJ font might not have installed which version are you using?
Posted Thu 20 Mar 08 @ 7:30 pm
i just bought it and downloaded it off of here. and i can see the search bar for lookin up songs in my database
Posted Thu 20 Mar 08 @ 7:45 pm
I have the same problem. The trial version worked fine, the one I paid for and downloaded does not display in the control button (both for effect and loop...)
Posted Tue 01 Apr 08 @ 10:15 am
The font could change depending on the skin you use (as the font is defined in the xml file of the skin). Verify that you have it.
Posted Tue 01 Apr 08 @ 12:47 pm
I shut the machine down (Vista laptop), and turned it back on... It may have been an issue with the registry or initialization or ??
Anyway, it works now... Thanks for your input.
Posted Tue 01 Apr 08 @ 1:13 pm
