My issue is precisely as described here: https://virtualdj.com/forums/77809/PC_Version_Technical_Support/Crossfader_Problems.html
Has anyone got any suggestions as to how to resolve it?
AutoHeadphones: Always
Crossfade: Smooth
Soundcard: Hercules MK2 (in both VDJ and Windows)
VDJ version: 5.0.7 Professional
Skin: same problem regardless which skin I use
Crossfade: Smooth
Posted Thu 28 Feb 08 @ 12:25 pm
Change the Soundcard Output setting drop-down to 4.1 Soundcard. Do not use the Mk2 icon option.
Posted Thu 28 Feb 08 @ 5:25 pm
Cheers I will try that tonight when I get home.
Posted Fri 29 Feb 08 @ 7:21 am
That worked! Thanks so much for your help.
Posted Mon 03 Mar 08 @ 6:22 am
