Has anyone used this mixer with VDJ? If so, are you able to control the VDJ mixer interface like in the Hercules DJ Console. For example, will the crossfader move on the screen when you cross fade on DXM01. Thanks in advance!
Posted Mon 06 Dec 04 @ 6:02 am
Yeh that mixer is cool, i could invest in one off those! would be an exelent compiment to Vdj, anybody any ideas if it will interface with Vdj?
Posted Mon 06 Dec 04 @ 1:28 pm
No, the DXM01 USB will not interface with VirtualDJ as each channel is a USB soundcard. In other words, you can configure VDJ to have 1 channel on each soundcard (thus, each channel on the mixer) and use the mixer as any regular mixer.
macourteau
macourteau
Posted Sat 11 Dec 04 @ 11:53 am
If it had, "ability to work seemlessly with Virtual DJ software I would have two tomorrow. What a setup that would be!
Posted Sat 11 Dec 04 @ 1:16 pm
It should work as a duel sound card and mixer. It's compatible that for sure.
Posted Sat 11 Dec 04 @ 5:36 pm
