Forum: Old versions
Topic: TCV Help
Hi
Got TCV with MK2, thing is it work or some time then cannot control the vdj with the TCV. But when u scratch or stop the TCV you can see the vinyl moving on the pc screen but the music keep playing and you have to use the software to stop and play.
You have to restart the vdj everytime
Posted Tue 26 Feb 08 @ 9:23 am
What version of VDJ do you use ? What kind of Timecode Vinyl ?
i download from this website and i bought tcv from vdj as well and i have a maya44 usb card. Thing it works fine for some time then stop responding
I think this is a limitation of the Demo-Version. Timecode only works for some time so you can test it and then stops working. But maybe a Teamer can confirm that.
Oh sorry! I didn´t read that you have the mk2! So you are using the Version of VDJ that came with the MK2? Have a look here https://virtualdj.com/products/comparison.html
Unter the Dj Console Version you can read > "Timecoded Vinyl Support" ----> Limited
But I don´t know exactly what that means.
So you not sure if its because its a demo thats why its stops. Can any1 from developepr team confirm this plz
With the demo, the Timecode is restricted to 5 or 6 minutes.
Jimmy B
