Is there a discount on VDJ when upgrading from Cue LE? Is this even possible?
Or Should i just get CUE pro?
Money in hand...let me know. Thanks
Posted Fri 22 Feb 08 @ 3:10 pm
CUE pro and VDJ pro are the same thing...It's just a branding issue ;)
Posted Fri 22 Feb 08 @ 3:42 pm
Do what ever is best value for money for you as they are identical pretty much, remember you can get a discount for owning the Herc on VDJ pro.
Posted Fri 22 Feb 08 @ 3:43 pm
I know they are the same but with VDJ you get a discount for owning a previous product. But when i enter my cue le S/N it says it is not valid. I was asking if the discount applies to owning cue le as well.
Posted Fri 22 Feb 08 @ 3:51 pm
Because you own the MK2, you should probably take advantage of the discount.
Enter your home edition serial #.
Posted Fri 22 Feb 08 @ 4:02 pm
