I know the Herc Mk 2 does not require an external power supply. However, when I connect analog external inputs to the rear, they sound very distorted - even at low levels. Does the Herc need the external power for line 1 and 2 analog inputs (as opposed to USB sound from VDJ)?
Also, where can I get this power supply?
Posted Fri 22 Feb 08 @ 12:29 am
I can't remember is the MK2 has the voltage listed on the back but if not contact Hercules for that info. You can pick the power supply up at any electronics store, Radio Shack has tons of different power supplies.
Posted Fri 22 Feb 08 @ 8:44 am
The best way is to contact Hercules service support ;)
Posted Fri 22 Feb 08 @ 9:43 am
You can always buy a powered USB hub and plug your controller in that way so it doesn't use the computers power.
Posted Fri 22 Feb 08 @ 1:03 pm
OK thank you all. I found a matching transformer, so I will report back once it's connected.
Posted Fri 22 Feb 08 @ 1:06 pm
Eric, it sounds like you're using something other than TTs on the input. If so, make sure your input's phono/line switch on the MK2 is set to "line." You may be getting distortion from the phono preamp on the MK2.
Posted Fri 22 Feb 08 @ 4:11 pm
Yes - I made sure of that originally. Thanks.
Posted Fri 22 Feb 08 @ 6:33 pm
9volt dc 500Ma recommended,
i use a "9volt DC 1000mA" "works perfect"
in the PDF manual it states the plug size etc
i got mine from a place called radioshack "in the USA"
Posted Fri 22 Feb 08 @ 6:41 pm
did it work? are you able to play analog inputs with out a problem? what is the part number of the adaptor
Posted Sat 23 Feb 08 @ 1:13 am
brand: radishack AC Adapter
9v DC 800mA (regulated) (0.8A is the same as 800mA)
Cat NO. 273-1768
2.1mm x 5.5mm plug end is needed
center post positive (+)
also will work:
-Uniross AC/DC Regulated 1.5 – 12V 700mA Universal mains Adaptor (UNI700RSF)
-Uniross AC/DC Regulated 3 – 12V 1000mA Universal Adaptor (AD101705)
the following specifications would be ideal:
9V DC/500mA; 2.1mm x 5.5mm plug;
center positive polarity
Cat NO. 273-1768
also will work:
Posted Sat 23 Feb 08 @ 8:55 am
i remember this issue long ago.
there may also be a problem with static coming out of the sound card due to it not being shielded enough.
you need to get rid of the neutral power bar in the power line of the computer/speakers. it's this little plastic device that cost 79 cents.
Posted Sat 23 Feb 08 @ 3:24 pm
Well, I used the power transformer and I still get a very distorted sound out of the Herc when using the analog inputs only. It's not an interfernce, or buzzing. Just very distorted. Maybe my Herc is bad.
Posted Sat 23 Feb 08 @ 3:52 pm
Try a different USB cable.
Posted Sat 23 Feb 08 @ 4:08 pm
Why would the USB cable be at fault? This is an analog issue...??
Posted Sat 23 Feb 08 @ 4:10 pm
I am telling you I had an issue similar and found my USB cable was bad, could also be your RCA cables.
Posted Sat 23 Feb 08 @ 4:13 pm
Just tryin to help mate:)
Posted Sat 23 Feb 08 @ 4:14 pm
Thanks I appreciate it. I eliminated the RCA cables originally. But I will try swapping the USB cable.
Posted Sat 23 Feb 08 @ 4:16 pm
Yeah... Weirder things have happened, but you never know.
Posted Sat 23 Feb 08 @ 4:20 pm
This has been a problem with this every sense the driver was updated to the 2007 driver. I beleave it is in the driver
Posted Tue 26 Feb 08 @ 3:46 am
in looking at Hercules site I found some info on this problem http://ts.hercules.com/eng/index.php?pg=view_files&gid=2&fid=28&pid=177&cid=6. They say the reason you get distortion is because to much line power is going to the mixer "The inputs of the console are made for consumer grade devices with a Line
level output (-10dBu), such as MP3 player, portable CD player, etc
Some DJ peripherals (using 2V Line level) or professional grade devices
(using +4dBV level) will overload the inputs signal and consequently create
distortion if connected to the DJ Console MK2 inputs."
Posted Tue 26 Feb 08 @ 4:22 am
