A friend of mine mixes with VDJ 5 rev. 6. He asked me to find out the solution for a problem he is experiencing: He loves throwing home partys and mixes himselt. He uses a 5.1 soundsystem wich is connected to the soundboard in the rear of the pc. He also has 2 slots in front of his pc (mic/headphones) wich he connected is headphone to. His problem is that he cant find the right configuration to set in VDJ so that he can hear both songs all the time in his headphones and just the one (or both) depending on the crossfader on his soundsystem. Does anyone know what he should set ?
Posted Thu 14 Feb 08 @ 11:49 am
inaltu
you could try this https://virtualdj.com/blog/tayla/ hope it helps
Tayla
Tayla
Posted Fri 15 Feb 08 @ 4:05 am
buy a cheap mixer 2 channel then plug the headphones into it... works well and makes it like real djing.. tell you friend..
Posted Tue 19 Feb 08 @ 10:29 pm
