I followed an amazing guide of how to broadcast with virtual dj. I am uploading it to listen2myradio.com. But when i do so it freezes the second i hit play and start broadcasting. I tried lowering the kps, went all the way down to 35. It was working fine at one point but no longer is. Any ideas?
Thanks in advance
Thanks in advance
Posted Wed 06 Feb 08 @ 4:01 pm
Yeah, stop broadcasting. Just kidding. It works fine otherwise? What version are you using, and the specs for your machine?
Posted Wed 06 Feb 08 @ 4:08 pm
Dude, I cannot help you on this but I am looking forward to reading your guide!!...
Good Luck
Phil
UK
Good Luck
Phil
UK
Posted Wed 06 Feb 08 @ 4:18 pm
not my guide lol found it on this forum
Yes it does work fine otherwords. it only freezes the second i hit play while broadcasting. im using version5.0
Posted Wed 06 Feb 08 @ 4:39 pm
Oh also forgot. my specs. its a 3.4 ghz processor with 1gb of ram. no sound card though. have an integrated one :(
Posted Wed 06 Feb 08 @ 5:37 pm
I used to broadcast on listen2myradio but found that shared servers were too unreliable and very very slow.
I used to also experience the same thing as you, press play everything would freeze and but otherwise fine. I believe it is the listen2myradio servers.
Do this: before your live show begins, set a playlist on automix for about an hour beforehand. I found that doing this along with commercial-type voiceovers, "the show will begin in 15mins..." sort of thing; fixed the problem.
But I had numerous people say they had connection troubles, and although the track title was showing up in the player window, no noise was coming through.
I eventually gave up on listen2myradio. It's servers are too taxed.
Posted Wed 06 Feb 08 @ 6:15 pm
do you know any other substitutions i can use besides listen2myradio?
Posted Wed 06 Feb 08 @ 6:17 pm
Yes buy the Full Pro Version and apply to play on Virtual DJ Radio
Kaoz
Posted Wed 06 Feb 08 @ 11:20 pm
LMAO! Love it!
Posted Fri 04 May 12 @ 5:54 am
@#1DJCavo, please do not spam the forum with posts like this!
Please have a look here:
https://virtualdj.com/wiki/Forum%20Rules.html
You post from above, is moderated!
Posted Fri 04 May 12 @ 6:52 am
