hey im using the trial of virtual DJ version 5.0, and im having a problem...i downloaded a bunch of effects (VST effects) and a bunch of them didnt work with virtual DJ, thats fine...so i deleted them from the sound effects window...but now the effects are still being listed in virtual DJ, under the effects window in the internal mixer, and also under the part on the bottom where you can use effects. its taking up alot of space and i dont know how to get it out of the program...can sum1 please help me?
Posted Tue 05 Feb 08 @ 10:07 am
Go to your "My Documents/VirtualDJ/Plugins folder, then click whatever folder coinsides with the effect (ex. SoundEffect). Delete the .dll file (and .ini, if present) for the effect that you want to remove. The next time you open VDJ, it won't be there ;)
Hope your trial is going well so far :)
Posted Tue 05 Feb 08 @ 11:12 am
thats what i did and it did not leave from virtual DJ...lol please help
Posted Tue 05 Feb 08 @ 12:59 pm
whoops...never mind i know what i did wrong. thanks so much though,
DJZJ
DJZJ
Posted Tue 05 Feb 08 @ 1:11 pm
