I'm using a Creative (Live) 24 bit external sound card (Sound Blaster)
Also using Numark Cue, Numark DMC2, and running into a Behringer VMX 1000, 5 Channel mixer.
I have the Sound card all set up but, not sure on the settings in the config.
Could I get some help on what the Config Settings should be at please.
Thanks
Rich
Thanks
Rich
Posted Wed 23 Jan 08 @ 10:52 pm
hmm... sorry dude, looks like you need a new soundcard. you need a soundcard that has at least two stereo outputs (no TCV) and at least two stereo inputs if you want to use TCV (3 if you want to record as well). I checked the Soundblaster page and it doesnt look like it has that.
But when you do get that card, you set the VDJ config to External mixer and ASIO (if the card you get supports it).
Posted Thu 24 Jan 08 @ 6:54 am
virtual dj up & running, but i can't get my headphones to work. what do i need to do?
Posted Mon 28 Jan 08 @ 7:35 am
