hi i have a little problem, i look through different forums but can`t find answer, so mb here smb can help me
How to make virtual dj not to send metadata while broadcasting? i mean i don`t want that tracks that i play via vdj were seen when smb listen to radio?!
Posted Mon 21 Jan 08 @ 9:31 pm
It is possible to disable this if you purchase pro.
hope to see you with us soon :)
Posted Tue 22 Jan 08 @ 8:51 am
i already have pro what i have to do ti disable?
Posted Wed 23 Jan 08 @ 11:36 pm
https://virtualdj.com/fusers/modifuser.html add your serial here so you can get the latest updates and the tool required to do it
Posted Thu 24 Jan 08 @ 5:56 am
what is the name of tool?
Posted Thu 24 Jan 08 @ 6:36 pm
It is DJS cels advanced option tool ,
Hope to see you as a pro user soon ;)
Posted Fri 25 Jan 08 @ 7:17 am
