thank you very much paz75!
now, i don't hear the timecode signal anymore!!
yet, i keep having the problem, when starting the TCV the song in virtual dj jumps to the end of the song. so nothing is played.
for example:
i select a song in the left side of virtual dj.
i see it loading, the moment i move the turntable the song get selected in red 3/4th or till the end.
strange
but i feel getting closer and closer to a perfect working system
thank you guys so much!!
for example:
strange
Posted Fri 18 Jan 08 @ 3:46 am
are you on relative or absolute mode in the TCV setup? btw, what timecodes vinyls are you using?
Posted Fri 18 Jan 08 @ 4:36 am
absolute. but i tried relative also.
i have virtual vynil TCV's.
Posted Fri 18 Jan 08 @ 5:16 am
HI
mute the monitors ànd activating smart mode were both the solutions...
I have on both channels 100% perfect signal and latency is set to the lowest.
sound is perfect clear!
Thank you so very much!, everybody
Posted Fri 18 Jan 08 @ 1:28 pm
What does it mean when one deck with TCV plays fine, the other one has like a distorted grumbling noise, sounds like someone is blowing into a microphone. The waveform when setting up the signal is erratic..everything is set the same way as the first deck, so i'm not sure.
Posted Fri 18 Jan 08 @ 8:51 pm
