So a few weeks back I was having a problem with virtualDj cutting many of my songs in half ,i.e. it would not load more than half the song to the deck. I tried changing the options to max load and that did not fix the problem. Bit I have found the solution what you need to do is find the song in your music library then
right click -> BPM -> Analyze as Other
then load the song again and it should play perfect.
It will not work if you just change your BPM Engine to Other you must do it by hand.
Posted Sun 06 Jan 08 @ 11:20 pm
I haven't yet experienced a song cutting in half but it's good to know there's a way around it in case it does happen, good tip.
Posted Mon 07 Jan 08 @ 2:27 am
