v1.11 will be released this weekend at some point for sure :)
Posted Fri 05 Sep 08 @ 6:15 am
thanks SBDJ
Posted Fri 05 Sep 08 @ 10:26 am
Hi Scott , the weekend came and went and no update , what happened ?
Posted Wed 10 Sep 08 @ 3:42 pm
Sorry guys, got a bit snowed under this weekend with some personal issues.
I'll try and get it done asap :)
Posted Wed 10 Sep 08 @ 5:36 pm
v1.20 has been uploaded, and is pending approval...
Changelog:
Implement user option for default jogwheel mode
Implement user option to control sensitivity of beat detection for LED flashing
Implement support for new keylock status query in v5.2
Fix VU meter level when music not playing
Some more small changes for cross-platform portability and buffer overflow protection
I've also updated the documentation to include the system requirements correctly!
Regards,
Scott
Changelog:
Regards,
Scott
Posted Wed 10 Sep 08 @ 7:18 pm
Hi Scott.
I've installed your mapper 1.10, but I've found some problem in the sync (e.g. playing the same song at 0 pitch in the two decks, the left (blu) running more than right (Red)). So is very difficout mixing during a date. I had must deinstall the dll from the device folder.
Have you fix this kind of problem in the new release?
Thanx for your support.
Fabio "F@lconrec" Lenzi.
Posted Thu 11 Sep 08 @ 4:38 am
You're saying if you load the same song to both decks, leave at absolute zero pitch and play them, they play at different speeds if you don't touch anything?! If you uninstall the mapper it goes away?!
I'm unable to fix this problem in the new release, as this is the first I've heard of it ;)
Does anyone else have this issue?
Stupid question - install the mapper, load the same song to two decks, don't touch the xponent at all. Make a macro keyboard shortcut to press play on both decks at the same time. What happens?
Posted Thu 11 Sep 08 @ 5:10 am
Make it.
Same thing. The songs play at different speeds (blu running more than red).
When I uninstall the dll the two decks and the song play correctly.
Posted Thu 11 Sep 08 @ 5:14 am
I have no idea why that can be, unless something strange is causing one deck to have bend/jog applied to it.
I'll have a look into it, but I won't have time until the weekend I'm afraid.
Posted Thu 11 Sep 08 @ 5:27 am
Thanx anyway.
Posted Thu 11 Sep 08 @ 5:32 am
Thanks to Moramax new version 1.20 is available http://www.virtualdj.com/addons/tools.html
Posted Thu 11 Sep 08 @ 6:44 am
Hi Scott , just downloaded the 1.20 thank you..
Unfortunately i have immediate problems , everything was perfect for about 30 seconds but then the christmas tree mode became a continuous fast flashing , unhealthy looking , any ideas ??
Thanks Paul
Thanks Paul
Posted Thu 11 Sep 08 @ 8:49 am
Things just got worse , trying to understand the problem i turned off my xponent and my pc crashed , that has never happened before , also now the xponent will no longer comunicate with my VDJ , please help urgently
Posted Thu 11 Sep 08 @ 9:05 am
Please could some one send me the 1,10 which i no longer have so that i can try to see what's going on....
Posted Thu 11 Sep 08 @ 9:08 am
Ok not the second but the third time that i installed the 1,20 things work again BUT mad christmas tree effect is still mad.
Posted Thu 11 Sep 08 @ 9:23 am
Very strange.
What is the beat sensitivity slider set to? It should be 2048 by default, which is the fixed value I was using before.
*Always* keep a backup of a plugin before upgrading it ;)
Posted Thu 11 Sep 08 @ 10:27 am
beat sens is or was at zero extreme left now i've put it to 2048 , will test now
Posted Thu 11 Sep 08 @ 10:46 am
Seems ok , lights working normally , how come this happened ??
Posted Thu 11 Sep 08 @ 11:16 am
No idea... never had these problems when I was testing it...
Posted Thu 11 Sep 08 @ 11:28 am
It works good for me man , I will be able to play some more with it after work.
Good job man
Good job man
Posted Thu 11 Sep 08 @ 12:10 pm
