what is wrong with virtual DJ and the loop problems when i try to use my maya44, cdj 800s, everythings hooked up fine, its just the loops or cue doesnt work. it works on the TCCD but not on the sound..
Posted Mon 17 Dec 07 @ 7:00 pm
oh and also i cant play the song from the decks.. i have to click the play button
Posted Mon 17 Dec 07 @ 7:01 pm
bump..
ok my only problem now is the looping and cueing.. anyone?
Posted Tue 18 Dec 07 @ 11:56 am
well are you trying to setup loops and cues from the cd decks or VDJ?
I strongly suggest using a midi controller for these and let VDJ control the loops and cues. I'm no TCCD expert since I use TCVs although many functions are locked on the trial version since its only there to give you a quick example of how it will work.
If you have already purchased the software please update your profile for better support, and hopefully someone with more knowledge of TCCD will be able to help out
Posted Tue 18 Dec 07 @ 12:15 pm
