Hi i'm looking for the home level plugins but am having trouble finding them i'm sure there's a way to track them down if someone would be kind neough to help.
Cheers,
The Raven
Cheers,
The Raven
Posted Tue 04 Dec 07 @ 4:59 am
add your serial then you can acess these
https://virtualdj.com/fusers/modifuser.html
Posted Tue 04 Dec 07 @ 6:46 am
there are one or two but you need to register your version of home edition before you can get access to them, you will find them in downloads area in the appropriate section... hope that helps
Tayla
Tayla
Posted Tue 04 Dec 07 @ 6:47 am
