Hi all,
just taking my first steps into VJ world and I've an undoubtedly noob question.
I've set up Numark Cue to output to my mixer so I can trim the sound quality through the DJIO with a left and right split of the 4 channels (left deck Numark cue: channel 1&2, right deck Numark Cue: channel 3&4)
Now I thought that when the crossfader of the total control was centre all 4channels (both decks) would be available at the mixer so I could headphone cue/mix on my mixer, but for some reason I only get a channel when I fade to to it on the total control.
Is there a way I can get both decks outputting through the DJIO at the same time?
Thanks in advance
Thanks in advance
Posted Sat 01 Dec 07 @ 1:03 pm
howdy i belive that in cue le this is disabled as it is a limited edition given as a gift with your console
it is similar to the VDJ home edition 2006
comparison
then in cue or VDJ pro all you need to do is dissable the cross fader in vdj/cue and use the mixer
check out the latest cue or vdj demo , to see how it works :)
comparison
Posted Sun 02 Dec 07 @ 4:22 am
Posted Sun 02 Dec 07 @ 11:51 am
