Forum: Old versions
Topic: ASIO help
I have just brought an external sound card....however the sound card is NOT an ASIO sound card
is there anyway I can install ASIO drivers to run the sound card....
at the moment i have virtual Dj Home 3.0
and i also have a mk1 with the DJC version
but i am looking at getting timecoded vinyls so i need an ASIO sound card...which here in South Africa has been impossible to find...
and will my basic Numark DM950 mixer be ok to work with timecoded vinyls or do i need a special mixer
and lastly what turntables would you recommend that are not to expensive...and if i need a different mixer what mixer would you recommend
thanks ALOT david
Posted Tue 20 Nov 07 @ 12:20 pm
why not check out the mk2 console it features an asio card and timecode support
plus you get the latest home edition with the posiblity to upgrade to pro
at a discount
i did take a look at it....
the only thing is...would it not be ALOT cheaper just to get an ASIO sound card
and turntables
than an mk2 and turntables
yes it would be cheaper if for example you buy maya44 or u46se as a soundcard both tested by many vdj users of this forum.
But you need a pro edition to work with tcv so a good solution for you is numark virtual vinyl wich has everything you need souncard+tcv+cue pro edition wich is exactly the same with vdj look here :
https://virtualdj.com/products/hardware.html
TCV do not need a special mixer to work so if you are happy with your mixer keep it.
HI , I HAVE PROBLEM WITH MY TIMECODES I HAVE 2 TECHNICS (LAST MODEL) , I HAVE MK2 CONSOLE , AND LAPTOP TOSHIBA QOSMIOG35, SO MY PROBLEM IS I OPEN THE SOFTWARE AND EVERYTHINGS IS OK , I CHECK IN CONFIGURATION AND SAY 100% VINIL , OK , AFTER 3 O 4 MINUTES THE MUSIC STOP AND I CHECK IN CONFIGURATION Y I GET 0% AND NOT SIGNAL , I HAVE TO REPLUGING THE USB CABLE FROM THE MK2 CONSOLE FOR THIS WORKING AGAIN , BUT AFTER 3 MINUTES O WHEN I START SCRATCH THIS HAPPEN AGAIN ,,, PLEASE HELP ME . I TRUST IN VIRTUAL DJ.
Try reinstalling the drivers for the sound card again and let windows do it. Check in Device anager and see if there is no ? mark for the driver. When the driver is not installed for the sound card, it will not work properly. Try unpluging the usb wire and then repluging back in and start the program and configure the time codes
Hi i cant seem to find pricing on virtual vinyl where can i find that kind of info
