So ... I recently purchased Dell laptop all specs required. it had to come with Vista.
I installed Virtual Vinyl and all was working well. I only configured on CD player CDJ 1000 MK2
I then updated to Virtual Vinyl 5.0 and tried to configure again..... Only one side works. When I try to auto config the right side I get that error message !!!!
can anyone please help me.
Eric
Eric
Posted Thu 01 Nov 07 @ 4:20 pm
Hi DJ Flex
Don't Know alot about Asio soundcards, because I've never had a problem but have you check out this
www.asio4all.com
I think you can downlaod new asio drivers.
As I said I don't know if this helps you.
Jimmy b
www.asio4all.com
Jimmy b
Posted Fri 02 Nov 07 @ 1:38 pm
Don't use ASIO4ALL, there is no need.
Did any settings change from the install? Try unstalling the driver and reinstalling. Once that is done plug in the card wait until it activates then start Virtual Vinyl
Posted Fri 02 Nov 07 @ 1:50 pm
BTW
What sound card are you using???
Jimmy b
Posted Fri 02 Nov 07 @ 5:14 pm
jimmy b wrote :
BTW
Jimmy b
BTW
Jimmy b
He is a VirtualVinyl user and using the VirtualVinyl interface.
Posted Fri 02 Nov 07 @ 7:26 pm
