my denon s1000 n maya44 work fine but vdj stop recognizin da signal idk y umm da vinyl in vdj spins but da song wont play any ideas why? i need help
Posted Tue 30 Oct 07 @ 1:50 am
You using ssl vinyl I f so tat is the problem and you will need to buy vdj vnyl until the ssl plugin comes out.
Posted Tue 30 Oct 07 @ 2:26 am
am using the timecode cd i downloaded from virtualdj.com
Posted Tue 30 Oct 07 @ 2:49 am
ohh sorry man I didn't see your full post. Emm I don't know how to help you man. I'm using time code cds pretty nicely. Do you get 100% in your time code readout?
Posted Tue 30 Oct 07 @ 3:35 am
ummm no I get vdj timecode signal 0% any way I can get dem to 100% srry for the trouble but am new at timecodes
Posted Tue 30 Oct 07 @ 4:07 am
any help?
Posted Tue 30 Oct 07 @ 7:30 pm
is der anyway anyone can help on dis?
Posted Mon 05 Nov 07 @ 10:48 pm
Try put the latency to auto n performances to fastest n untick both overclock n safe mode.. N in the config of timecodes, hit auto config few times n make sure u put it on cd on vinyl.. N also make sure the cable is all set:)
Hope to see u as pro user soon:)
Posted Tue 06 Nov 07 @ 9:45 am
