ok i have got the full set up but there is a few problems
i have got the esiu46dj and i have emulated it with asio for all drivers but i have set the latency to 128 and im running 2 mb of ram but while playback i get the "***overload!***" msg in the asio4all control panel and the music skips .. is there any one who can help me solve this problem
Posted Sat 27 Oct 07 @ 8:47 pm
Yes just increase you latency
Posted Sun 28 Oct 07 @ 1:13 am
yeah i know but when i do that i get a delay and thats y my latency is so low cause im a scratch dj
Posted Mon 29 Oct 07 @ 5:09 pm
Why are you using ASIO4ALL? The U46DJ has native ASIO drivers last time I checked..
Also a buffer size of 128 translates to 3ms (input) latency which IMO is something you cannot do without _serious_ hardware and probably is out of reach for the u46 anyway..
I can run my interface, the RME HDSP RPM, at 32 (0.7ms) with my regular DJ software, which is not VDJ. I would have to try, but I would expect VDJ to just be able to handle 3ms latency with the RME which is a way, way better interface then the U46DJ ..
Posted Tue 30 Oct 07 @ 9:06 am
dont use asio4all, you should try the 1.016 driver. You can also try lowering the input sliders too. Latency should be set to auto in vdj.
Is this a laptop? does it not overload running off the battery?
Posted Tue 30 Oct 07 @ 7:55 pm
