Hi ,
I've just installed rev5 , before that everything worked great
now mixlab 1.3 skin doesn't work anymore, I get the error message "error line 0 xml"
delete and reinstall the skin doesn't help,
some other skins still work
what should I do ?
what should I do ?
Posted Wed 24 Oct 07 @ 12:43 am
strange that is usualy the logo code i will test it too
Posted Wed 24 Oct 07 @ 12:26 pm
Or maybe you set your graphic card to 800x600? since default skin runs under 1024x768 and some video cards don't make the change autocatically.
Posted Wed 24 Oct 07 @ 7:17 pm
When I was debugging my skin, I always got the "line 0" error no matter
on which line the real issue was (bug in vdj). So it's not necessarily an
error in the first line.
If it is though, it could be the wrong version of skin? Happened to me 1ce.
Posted Wed 24 Oct 07 @ 10:14 pm
