Hi iv been using vjd for a while now but always wanted to go back to vinyl so go some TCV A MAYA 44 USB SOUND CARD.
Im using 2xtechnics 1210s a gemini ps-04 mixer.
I have 3 channles on the mixer with a line or phono switch at the back depending what im using anyway if i put the switch to phono its over powering with lots of noise if i set the switch to line and turn the maya down to 1/4 it sounds ok but tooooooo quiet to do anything with now im hearing the tcv noise all the time witch after a long time now is doing my head right in!!!!!!!!!!!!!!!!! aaaaaaaaaahhhhhhhhhhhhhhhhhhhhhh!!!!!!!!!!!!!!!!!!!!!! get the picture?
any help would be very good as iv been djing for a long time now and never came across anything like it?
i notice other people are having the same troubble but are too bloody tight to buy vdj so are not getting any help !!!!
anyway BIG THANKS TO ANYONE THAT CAN GIVE ME A HAND BYE FOR NOW SNIPPS
Posted Tue 23 Oct 07 @ 11:42 pm
Go into the Maya44 USB Control panel and MUTE the Monitor In 1&2 and In 3&4. Input level at about 1/2 level. Output at Max. Now go back and run the Timecode Config.
Posted Wed 24 Oct 07 @ 2:07 am
great thanks all is good now for me to get the y splitter cables to use my vinyl as well thanks again
Posted Thu 25 Oct 07 @ 12:49 am
there is a bypass feature that works pretty well so you dont have to buy Y splitters. Make a shortcut and give it a try 1st. Before ver.5 it didnt work well but since the new audio engine it much better.
Posted Thu 25 Oct 07 @ 12:31 pm
That was a big help to me .. I couldn't figure it out .. thanks a ton.
Were can I find this bypass feature in ver 4.3 ? ... I use 1 cdj800 for time code .. but would like to be able to play regular CDs in it as well.
I was thinking a Y splitter and sending it to another channel.
Posted Sat 10 Nov 07 @ 6:10 pm
I think the bypass was removed from 4.3 it didnt work good at that point. Have you thought about upgrading to 5?
My response was dj snipps with tcv. I think you should be able to run the bypass on cd's with no problems in ver 5. You can either install both on the same machine or after you upgrade your not happy you can just roll back to 4.3
Posted Tue 13 Nov 07 @ 7:32 pm
