Hi all,
Been playing around with VD5 since downloading it yesturday. Been on it for a couple of hours now and I keep getting a DirectX error popping up.
What is this error, how can I sort it out.
Jimmy b
Jimmy b
Posted Wed 17 Oct 07 @ 4:14 pm
Whats the actual error?
If it's regarding a missing file, I'd recommend updating your DirectX 9 runtime to the latest version :)
Posted Wed 17 Oct 07 @ 5:15 pm
It just cames up with
"Error in DirectX" in a little error box when I first opened VDJ5 and it has popped up 5 times whilst playing.
Where do I go to update DirectX 9 runtime, the microsoft website ???
Jimmy b
Jimmy b
Posted Wed 17 Oct 07 @ 5:24 pm
Downloaded the latest version of DirectX 9 runtime and installed, from the Microsoft website.
Just messing around with something else at the mo, will try to see if the error is sorted later if I got time.
Jimmy b
Posted Wed 17 Oct 07 @ 8:05 pm
No Luck,
This is the error I get "Error in the sound driver of DirectX"
Can anybody help me please.
Jimmy b
Posted Wed 17 Oct 07 @ 8:38 pm
I had that happen and It was because I installed a video card and it chenged some of my default settings.
Check your soundcard settings in control panel and in VDJ.
Posted Wed 17 Oct 07 @ 8:43 pm
try mk2 in wdm mode..
Go to herc sound control n choose wdm
n in setting of vdj
input: none
output: headphones
sc.. mk2
see if that helps..
n in setting of vdj
input: none
output: headphones
sc.. mk2
see if that helps..
Posted Wed 17 Oct 07 @ 8:58 pm
Thanks spinnaJ
Changed my herc settings as you describe,
When I open VDJ 5 with my Herc plugged in I don't get the error, It seems fine.
Without the Herc I get the error, So it seems to be a fault with my onboard sound of my Laptop if you get what I mean.
Jimmy b
Jimmy b
Posted Wed 17 Oct 07 @ 9:16 pm
get the asio4all for ur soundcard if next time u need to use timecode. Actually with ur mk2 card, u won't really need this:)
http://www.sudue.com/common_db/asio4all/
dl the v2.6 ,it the most stable so far..
There is no faulty on ur onboard sound :)
Posted Wed 17 Oct 07 @ 9:21 pm
Got it I think spinnaJ
In the Sound set up in config of VDJ, without my herc connect I had no so Soundcard highlighted. So I clicked on Primary sound Driver, then closed VDJ.
I re opened VDJ and got no error.
Fingers crossed I've sorted it.
Jimmy b
Posted Wed 17 Oct 07 @ 9:28 pm
Glad u sorted it.. njoy mates:)
Posted Wed 17 Oct 07 @ 9:29 pm
jimmy b
you will get the error message vdj is just telling you to change sound settings so you can hear it without herc just reset to single output, sound/ simple and use pc/lappy sound card...
Tayla
Tayla
Posted Wed 17 Oct 07 @ 9:31 pm
I get it now Tayla
Cheers matey,
Jimmy b
Posted Wed 17 Oct 07 @ 9:40 pm
tayla wrote :
jimmy b
Tayla
Tayla
I was going to say the same thing...LOL
Posted Wed 17 Oct 07 @ 11:45 pm
hehe
Posted Wed 17 Oct 07 @ 11:47 pm
Hi there..
I'm getting the same DirectX error on my new laptop.
I'm not using any timecode CD's.
I usually plug the phono-RCA cables from the sound card straight to the mixers.
I just changed to this Dell XPS laptop running Vista.
Bought a new Maya44 USB Soundcard for this.
Previously i was using a Creative PCMCIA external sound card on a Lenovo no problems.
I've got VDJ Version 5 installed. It's running the latest DirextX 10.
I play a song and the screen display just doesn't move.
I can't mix any songs, I can't hear any sound.
Help! I got a gig in two weeks time at a big club. :s
Thanks!
Distressed in Malaysia
Thanks!
Posted Wed 10 Jun 09 @ 9:03 am
jimmy b wrote :
I get it now Tayla
Thank goodness, I was afraid you would never GET IT. :^)
Posted Wed 10 Jun 09 @ 9:56 am
Wow how quickly time flies, just awoke from a snooze saw this post a read that JimmyB having problems with is Four X , I meant direct X, until I looked at the date posted, wonder if he got it sorted lol. I'm afraid to go to sleep in case I lose another year or two, beam me up scottie.
Posted Wed 10 Jun 09 @ 3:41 pm
You'll be fine, there, Rip Van Winkle, hehehe ;)
Posted Wed 10 Jun 09 @ 4:33 pm
Hi;
I get this error when I open Virtual Dj:
Error on the controler of Direct X
Can somebody help me?
Posted Tue 07 Jul 09 @ 8:43 pm
