I am currently at a gig and am unable to get VDJ to work I can load a song, but it won't play. I am unable to reinstall the soundcard drivers due ti "active device mgr", which is not true. I can't even install in safe mode. wth? Help!!!
Posted Sun 14 Oct 07 @ 12:10 am
what card do you have
what are you trying to do?
Posted Sun 14 Oct 07 @ 12:50 am
I'm screwed. I am using a maya 44. I just discovered that my device mgr is hosed. The is nothing listed. Damn!
Posted Sun 14 Oct 07 @ 1:19 am
did u try a reboot, use onboard sound?? if maya is broke??
Posted Sun 14 Oct 07 @ 1:59 am
Yep. No souncard detected.
Posted Sun 14 Oct 07 @ 2:11 am
Sounds like a windows issue. I have nothing listed in my device manager.
Posted Sun 14 Oct 07 @ 10:51 pm
