I'm getting the following message when I install VDJ
"COULD NOT INITIALIZE INSTALLATION. FILE SIZE EXPECTED = 38088054, SIZE RETURNED = 38088290. THE PARAMETER IS INCORRECT",
Any ideas????
Any ideas????
Posted Thu 11 Oct 07 @ 10:19 pm
Clear your Internet browser's cache and try downloading the file again. Sometimes when I download a file from the Internet and try to run it, I get a similar error.
Internet Explorer 7 saves the same file if one does not empty the "Temporary Internet Files" first.
- Go to "Tools">"Internet Options">"Delete...".
- Make sure to click on the "Delete files..." button under "Temporary Internet Files".
- Go to "Tools">"Clear Private Data...".
- Make sure the "Cache" is enabled.
- Click on "Clear Private Data Now".
Posted Thu 11 Oct 07 @ 10:27 pm
i have just purchased Virtual Vinyl 5.0 and I am getting the following message.
An I/o error occurred while installing a file. This is normally caused by bad installation media or a corrup installation file.
I have tried this on two separate laptops. 1. is win xp pro and the other one is Vista ultimate...same error on both
Help please
Help please
Posted Fri 12 Oct 07 @ 6:05 am
please try the latest update from the update section
https://virtualdj.com/update
Posted Fri 12 Oct 07 @ 2:42 pm
Is Virrtual Dj 5 more stable on Vista or XP?
Posted Fri 12 Oct 07 @ 7:53 pm
its stable on both but vista has a vastly improved video and sound api
which means video and audio works better :)
Posted Fri 12 Oct 07 @ 10:32 pm
Virtual Vinyl 5 n Virtual Dj 5 is the same n is stable:)
Posted Fri 12 Oct 07 @ 11:03 pm
