Hey all,
I previously was using Rane Serato's Scratch Live and it kept on crash my laptop, now im trying to use VDJ, I've watched the link on youtube on how to connect my system with an SL1 sound card but I believe the TTM57SL has a built in sound card. When I plug it in it doesn't detect the sound card and stays as an ASIO Sound Card. Can someone help me connect my system?
Thanks
DJK
Thanks
DJK
Posted Thu 11 Oct 07 @ 7:54 pm
You need the latest drivers :
http://www.scratchlive.net/forum/discussion/?discussion_id=40273
Should work then I think
Posted Thu 11 Oct 07 @ 9:24 pm
So download the program and it should work?
Posted Thu 11 Oct 07 @ 9:37 pm
So i installed the driver, it detects the TTM57SL but it still won't play, what am i doing wrong is it the setting or what? Basically I need setting up VDJ for dummies explaination thanks
Posted Fri 12 Oct 07 @ 8:48 pm
run Serato then close it
then open vdj
then open vdj
Posted Fri 12 Oct 07 @ 11:20 pm
I've tried that and it still doesn't do anything, with a setting I chose before it tries playing and you can see the beat trying to move but at an extrememly slow spped that it won't reach one sec in the song? weird
Posted Thu 18 Oct 07 @ 2:50 am
Same here. What are we doing wrong. Has anyone else had success with the ttm57sl and VDJ?
Posted Thu 18 Oct 07 @ 9:49 pm
Has it just been produce for the sole use of Serato, I wonder.
Jimmy b
Posted Fri 19 Oct 07 @ 12:42 am
No, you can use the ttm-57sl soundcard ok with VDJ. What version of Serato did you install, because I think you need to download and use/install 1.7.4 or above to get the asio drivers. Then you can set it up in the VDJ control panel.
A
A
Posted Fri 30 Nov 07 @ 12:57 pm
I have SSL 1.8 with the ttm57 and still cannot get VDJ to work with it.
Posted Fri 11 Jan 08 @ 1:02 am
it works perfectly fine for me. i also have 2 cdj800 mk2 running timecode.
Posted Fri 24 Apr 09 @ 8:48 pm
You can't use the joysticks/functions of the 57 with VDJ can you?
Posted Sat 08 Aug 09 @ 4:58 pm
im having a problem...i can only get one side working for me...i use 1200s...but for some parties (communions kid parties etc) i dont bring my 1200s in..i just take my 57 in and run serato..but virtual dj has a great automix function for parties like this....for some reason i can only get the channel 2 working does anyone know how to get both
Posted Sun 20 Jun 10 @ 8:28 am
