Hello.
We just released a new version, called "v5.0 revision 4".
As the name hints, this version doesn't really bring any brand new feature.
Instead, it's all about stability.
We postponed the new-features-list for the next v5.1, and in this version we only focused on fixing every single bug, crash, freeze, glitch or other small annoying things that have made their way in the previous revisions of version 5 (and before).
So this "v5.0r4" is probably the most stable version since AtomixMP3 2.3.
I know some of you have been complaining that Atomix Productions was getting too focused on not-essential-for-everybody-features instead of reliability. We have heard you, and here is the answer. I sincerely hope it will satisfy your expectations.
Posted Sun 07 Oct 07 @ 4:47 pm
Thanks for the AWESOME work on this Rev release.....
It works FANTASTIC at my PCs... Love it ;)))
Stable, solid, fast and safe...
Posted Sun 07 Oct 07 @ 4:50 pm
Bravo!
Against my best judgement, I'm gonna' use it at a wedding today!
I figure "hey!" 5.0 rev3 crashed twice yesterday during a wedding, could it get any worse?
crash guard didn't seem to recover anything, it simply allowed you to finish the song that was playing, cue up winamp, hit recover, vdj crashes, then you restart and keep on truckin' along!
other than that, I've been very happy with the progress. I know it takes time, and lots of troubleshooting.. you'll never hear me complain about bugs!
I appreciate all the hard work stef!
Posted Sun 07 Oct 07 @ 4:57 pm
Crashguard fixed, and hopefully all crash bugs too ;)
Rev 4 is pretty damn solid :)
Posted Sun 07 Oct 07 @ 5:00 pm
Also, Please note that the included manual from the install is updated. So, please refer to the manual for any of the Configuration dialog changes and you will probably find your answer.
My Documents -> VirtualDJ\\VirtualDJ 5 - User Guide.pdf
One key explanation added is on page 19 which talks about how the Automix mix points are used during automix. For all the automix user's I strongly recommend you read this section.
Posted Sun 07 Oct 07 @ 5:50 pm
Hmmm all i see in the download section for 5.0 is the FULL install....
Am I missing something? Where can I download the update to rev.4?
..I am currently using rev.2
Posted Sun 07 Oct 07 @ 6:46 pm
It's a full install
Posted Sun 07 Oct 07 @ 6:52 pm
OKay I downlaoded and ran the set-up on my test machine,
I go to enable my DAC2 and I notice..........
NUMARK:
PCDJ:
Hercules: HDC v1/v2
M-audio: xPonent
Denon: HC4500
Behringer: BCD2000
Ion: iCue
XP10
D-VINAL
WEBCAM scratching.
That is a huge list of supported controllers
oh yes - I forgot timecodes
Well Done ; Well Done indeed
NUMARK:
- iCDX
- DMC2
- Total Control
PCDJ:
- DAC2
- DAC3
Hercules: HDC v1/v2
M-audio: xPonent
Denon: HC4500
Behringer: BCD2000
Ion: iCue
XP10
D-VINAL
WEBCAM scratching.
Posted Sun 07 Oct 07 @ 7:30 pm
Whoop, gonna test this out:)
Posted Sun 07 Oct 07 @ 7:40 pm
Great work team!
Posted Sun 07 Oct 07 @ 7:55 pm
Thank you, dev team!
Posted Sun 07 Oct 07 @ 8:27 pm
Looks good hope i get better results!
Timecodes??? cant see them, where did you see that?
Posted Sun 07 Oct 07 @ 8:35 pm
So do I uninstall the rev2 then install this version or can I just install over the old?
Posted Sun 07 Oct 07 @ 8:36 pm
i just installed over the old one no problem
Posted Sun 07 Oct 07 @ 8:40 pm
Can't wait to put it to the test...Thanks for listening!!
Posted Sun 07 Oct 07 @ 8:43 pm
Just install over the old..:) n u be kicking with v5 rev4.hee
Posted Sun 07 Oct 07 @ 8:46 pm
uuuuuuuuuuuuuuuuhhhhhhhhhhhhhhh ...... well sclavel and norway recommended it , so that was good enough for me .... i threw my usual caution to the wind ..... it's working great .... got all my old samples and virtual folders and comments and effects ......putting it through it's paces ......
somebody cue up " this is all i ask " ( Tony Bennett )
Posted Sun 07 Oct 07 @ 9:48 pm
hey Dj Marcel said timecode plugs where there was he wrong???
Posted Sun 07 Oct 07 @ 9:56 pm
OK then am i STILL missing something because when I download it it.. the filename is "install_virtual_vinyl_v5.0.rev2"
Posted Sun 07 Oct 07 @ 10:03 pm
Hmm.. just be sure that u dl the correct one n save it in one of ur prefer folder in ur system.. After that.. go to that folder n u will see the new dl file.. Click the exe file n start installing n be sure to place it over to ur existing folder where u have ur v5 r2.. It will then automatically upgrade:) Hope i explain well.hee hope that helps ya:)
Posted Sun 07 Oct 07 @ 10:08 pm
