When i start up Virtual DJ with my *CONNECTED* ASIO USB Soundcard (ESI U46SE) everything is ok.
When i start the Software with configured USB Soundcard but *still NOT Connected*
i received an Error like "Skin Resolution does not match the screen".
Greets,
Heiko
Greets,
Heiko
Posted Sat 06 Oct 07 @ 1:43 pm
Just make sure ur monitor resolution is not smaller than the skin u wanna use. This is not a bug:)
Posted Sat 06 Oct 07 @ 1:55 pm
Again,
when i start VDJ with connected USB soundcard, it works !!!
wen the usb device is not connected i get the error.
I do not change my screen resolution ;-) - The Skin is the default skin and,
as i wrote with connected card it works without any problem.
Regards,
Heiko
Regards,
Heiko
Posted Fri 21 Dec 07 @ 10:01 am
this problem can be caused by a change of sound card as it can confuse the direct x engine simply changing the sound config then re running vdj should fix it :)
Posted Fri 21 Dec 07 @ 12:05 pm
