Hi everybody,
I was wondering if I could use the MK2 console in my laptop and have the sound output from the Audigy2 ZS pcmcia card ? What do you think?
Thank you for all your consideration
Posted Fri 05 Oct 07 @ 6:34 pm
it is possible to select that as the only output card
but if you ever wanted to use both you would need to upgrade to pro
Posted Fri 05 Oct 07 @ 7:28 pm
You could do that, but why? I've been using the internal soundcard in the MK2 with stellar results...I think it sounds great, and so does my audience :)
Posted Sun 07 Oct 07 @ 10:20 pm
For my 1000 post i would conclude...yeah mk2 is still decent for a soundcard even tho its not the high end ones..BUT it still werk great if ur setting is good;)
Salute to mk2.hee:P
Salute to mk2.hee:P
Posted Sun 07 Oct 07 @ 10:24 pm
Thank u again guys ;)
Posted Wed 10 Oct 07 @ 2:14 am
Anytime :) BTW, the Pro version is definitely worth the investment. I was really surprised by how much more you get...Like effects and samples downloads, especially. Plus, pro actually makes it easier to work with your music, including ID3 tag support (yeah, I know, another commercial...I'm just happy with it is all)
=D
Posted Wed 10 Oct 07 @ 8:03 pm
