I'm just starting out as a dj. wanna run virtual dj 5.0 with a dm2 as a controller (for now) and I need a mixer and some turntables.
I don't know wat i should get. I get something cheap for now till i get more into the djing.
Choices for a mixer
a) Numark DM950
b) Numark DM950 USB
c) Numark DM1050
d) Numark DM1001x
e) Numark DM1002KMII
f) Gemini PMX 02
g) Gemini PMX 03
Choices for turntables
Stanton Blem T.60X Direct-Drive Turntable
Numark Blem TT1650 Direct-Drive Turntable
Numark Blem TT200 Direct-Drive Turntable
Choices for a mixer
a) Numark DM950
b) Numark DM950 USB
c) Numark DM1050
d) Numark DM1001x
f) Gemini PMX 02
g) Gemini PMX 03
Posted Mon 01 Oct 07 @ 1:58 am
first start out by buying VDJ, then invest in a soundcard like the ESI Maya 44 USB.
Once you have this I would recommend the Numark TT200 over the other 2 choices you've listed. as a mixer your not leaving much to bargain with although the Numark DM1002MKII might be your best bet.
Best Regards
DJ White Devil
PS: if your going with TCV or TCCDs I strongly recommend having a minimum of 1GB of ram if your running Windows XP or 2GB on Vista
Best Regards
DJ White Devil
Posted Mon 01 Oct 07 @ 3:27 am
