I have a i book g4 i put vdj on it ut when i'm djing it always look like it bout to frezze or something it like it running slow can some1 help me
Posted Sun 23 Sep 07 @ 11:46 pm
what is the g4s spec the average g4 only justs meets the bare bones requirements
Posted Mon 24 Sep 07 @ 2:08 pm
so it not a good computer 4 vdj
Posted Mon 24 Sep 07 @ 8:19 pm
its not ideal no its not great for any dj program
try to set fastest , and autolatency in performance options
Posted Mon 24 Sep 07 @ 8:21 pm
k i will it and why when i download skins sample i cant used them
Posted Mon 24 Sep 07 @ 10:53 pm
https://virtualdj.com/forums/70110/MAC_Version_Technical_Support/Important_Information_Regarding___Skins_For_Mac_.html
for info on skins :)
they are currently packaged as exe which will be fixed soon , if you pm me the one you want i will send it to you
Posted Mon 24 Sep 07 @ 10:58 pm
