Another great skin !!
- A lot of possibilities included the new autoscratch function
- Different screen resolutions fo all users
- Very nice design especially the turntables
- Nice colors
I really like it.
Maybe I would post other comments after many tests.
Clax
- Nice colors
I really like it.
Clax
Posted Sun 24 Oct 04 @ 7:41 am
I found a bug into the 1024*768 (not tested the another one): The BPM screen on the right desk displays the BPM of the left one.
Posted Sun 24 Oct 04 @ 7:46 am
A little suggestion:
--> Could you add the possibility to create a temporary action on the kill equ by a right click ?
Thanks in advance.
Clax
Thanks in advance.
Clax
Posted Sun 24 Oct 04 @ 5:57 pm
Sure! Working on it.
Posted Mon 25 Oct 04 @ 1:00 am
Thanks.
That's the same problem for a temporary play with a right-click on "play/pause".
Clax
Clax
Posted Mon 25 Oct 04 @ 6:05 am
Maybe I should send it to you first for thorough testing before posting. :-)
Posted Mon 25 Oct 04 @ 1:41 pm
hello i wonder what the "auto_scratch" do.
when i want to use this skin i have to rewrite the xml.
i deleted the "auto_" from channel 1 and 2
Posted Mon 25 Oct 04 @ 3:14 pm
auto_scratch is a new feature in VirtualDJ 2.03. It is described here:
http://www.virtualdj.com/support/developers/autoscratch.html
Auto_scratch modules transform the sound to make it easier to scratch. For example, the "Forward scratch" module will play the samples at full volume when scratching forwards, but the sound will be muted when you scratch backwards.
macourteau
macourteau
Posted Mon 25 Oct 04 @ 3:21 pm
DJ Manixx you can send me everything you want; no problem.
Posted Mon 25 Oct 04 @ 6:35 pm
My problem with the (1280 x 800) is that I cant scratch with channel 2? do you think that its actualle my software? I dont 'cause the other skins scratch normally. Any ideas?
Posted Tue 26 Oct 04 @ 10:22 pm
No It's not U. I'm just uploading an updated one with the bugs fixed.
Posted Tue 26 Oct 04 @ 11:54 pm
thx , besides that you're skin is the one I love man. I use a VaiO and the 1208 is exactly what I neede, cool turntables!
Full blast
Full blast
Posted Wed 27 Oct 04 @ 1:31 am
Hi DJ Manixx;
Did you update the 1024*768 too ?
I really love your skin but I don't have a large skin.
Clax
Clax
Posted Fri 29 Oct 04 @ 12:44 pm
Yes I did.
Posted Fri 29 Oct 04 @ 5:55 pm
It's great to see another wide screen skin posted!! Thanks a ton.
I like that the wide screen users are getting another choice.
I'll be playing around with this one at home, for now tho I'll keep using Jims wide screen for work. Before I got the wide screen I'd been using the black mix-station skin. I hope someday someone will make a wide screen version of these skins.
(as more and more users upgrade to new laptops, wide screen skins will be more in demand.)
Posted Fri 29 Oct 04 @ 6:27 pm
I already have a 1440x900 skin made and ready to go. That is the highest resolution of my laptop. Maybe one day, there will be a demand for it.
Posted Fri 29 Oct 04 @ 10:11 pm
Mine only does 1280 x 800.
Posted Fri 29 Oct 04 @ 10:26 pm
Hi manixx;
Is it possible to obtain your 1024*768 updated ?
Thanks in advance
Thanks in advance
Posted Sun 31 Oct 04 @ 6:16 pm
I can send it to you. I don't know why it has not been posted yet. I even tried to send it again and it said there was already a skin with that name. Just let me know where to send it.
Posted Sun 31 Oct 04 @ 10:25 pm
Hey
I can't use the skin! VDJ says: error line 325??
What should I do?
GRTS
TOM
What should I do?
GRTS
TOM
Posted Mon 01 Nov 04 @ 12:17 pm
