1024X768, I just posted under this topic cause I thought the person made both versions and can help me. Thanks Brian
Posted Wed 26 Apr 06 @ 10:24 am
Workin on it.
Posted Thu 27 Apr 06 @ 5:45 pm
Thanks. Brian
Posted Tue 02 May 06 @ 1:09 am
Funny thing is that this skin 1024X768 works on my other machine without external video enabled, I don't know if that will help you or if you know of a bug. Thanks Cheers Brian
Posted Sun 04 Jun 06 @ 9:55 am
can someone PLEASE tell me how to resize the beat scrolling window. i shrunk it and i have no idea how to get it back. thanks!
Posted Tue 06 Jun 06 @ 4:06 am
did you edit the XML or did you just change the size the zoom size when using the skin?? If you didnt touch anything in the XML then all you should have to do is click on the waves with your mouse and scroll the wheel.
Posted Tue 06 Jun 06 @ 4:13 pm
