Hello world,
How do i make my samples record at a higher volume. I have "drops" from music artist and i want to put them in the samples list but they sound too low after i try to loop them with the sample feature. Is there a blog that focuses on the sampler or can someone tell me how to get a higher volume output on samples
Posted Thu 16 Aug 07 @ 2:46 am
i had some samples that were too quiet so i used 'wavepad' to amplify it.
if u searched google, im sure you will find it or something similar
Posted Thu 16 Aug 07 @ 2:54 am
I djing using a hercules console 4-mx , i been have a problem ,volume is to low and even i've hoop it with a mixer still low, what can i do to increase the volume?
Posted Wed 08 May 13 @ 1:22 pm
Don't hijack the thread. I tried to help you in the thread you already created. Did you look there yet?
Posted Wed 08 May 13 @ 2:23 pm
Try hooking up your laptop using your internal soundcard into a speaker system and play songs in VDJ just to check if there is any problem with the levels in your laptop system first.
If there is a Big difference in the output over what you're getting from your Mix-4 system then download the latest drivers from Hercules website, Un-install the Hercules drivers from the control panel in your computer, disconnect your Mix-4 and reboot your computer.
Now install your new drivers and follow the install instructions carefully, It'll be a good idea for you to read their installation procedure manual before, just to make sure the full installation as been completed successfully...
I have one and don't have those issue you are having, so it just might be an installation problem..
Good Luck..
Good Luck..
Posted Wed 08 May 13 @ 2:36 pm
