Fellow Dj's,
I seem to having a bit of trouble with the setup of VDJ - Hercules MK2 - EXT Mixer. I have read numerous threads / blogs and still i am running into trouble. I have managed to hook the MK2 console up with my Stanton M-304 mixer(as said in various threads and blogs - 1/2 - 3/4 output of MK2 to input line's of mixer, set Ext mixer mode etc..)everything seems to work until i mix tracks 1-2, and then select track 3 and drag it to deck A then both decks stop playing. Also when deck A is playin and is the active deck, when i click the tab button (or try to shift decks) i get big irregularities with the sound. I know i must have something wrong with the setup but cant figure out what.......a desperate dj needs help!!!
Thanks in advance
Thanks in advance
Posted Fri 03 Aug 07 @ 5:21 pm
Hi there, to my understanding, herc mk2 came with djc edition that only werk with the console n cant use that external mixer option.. N timecoded permitted is abt 5 minutes only. SO if u did own the pro version do register it here
http://www.virtualdj.com/fusers/modifuser.html
or r u using the latest trial v4.2?
Posted Fri 03 Aug 07 @ 6:37 pm
thanks for the reply spinnaj
yes...i am using the djc edition of VDJ but why does it have the ext mixer option in the hercules control panel if it doesnt support it??? All i want is to use the hercules dj console as an ext sound card with or without any functions. Is this not possible without the pro version??
Posted Sat 04 Aug 07 @ 6:10 pm
sorry as stated only pro can output to an external mixer
when you bought the mk2 you bought the unit not the software which was a gift to get you started
but you can upgrade at a
discount becuase you own the mk2
Posted Sat 04 Aug 07 @ 6:51 pm
thanks for the clarification skyfxl..i guess i'll have to upgrade then to the pro version.
Posted Sat 04 Aug 07 @ 6:59 pm
you wont regret it :)
as youl get skins , plugins and free updates :)
Posted Sat 04 Aug 07 @ 7:08 pm
And more options mode too.:)
Posted Sat 04 Aug 07 @ 7:10 pm
We do have that choice in V3.4 so I cant see why it would not work as long as the MK is plugged in.
Posted Sun 05 Aug 07 @ 1:13 am
Thats what i thought too pfd50 but apparently its not......
Posted Sun 05 Aug 07 @ 3:27 pm
learn more on the limitations here
http://www.virtualdj.com/products/djcedition.html
Posted Sun 05 Aug 07 @ 6:40 pm
Having some trouble today. Just hooked up 2 brand new pioneer cdj-800mk2s to the inputs of the hercules mk2 dj console. No timecode signal found? Cannot control virtual dj with the pioneers. Any ideas, this is driving me crazy. Please help.
Posted Mon 06 Aug 07 @ 7:28 pm
You may have to lower the signal for the timecodes. I made a tool to do this available here:
http://www.virtualdj.com/forums/73431/Hardware_Technical_Support/CD_TimeCode_Utility(Use_if_your_timecode_is_to_loud).html
Posted Mon 06 Aug 07 @ 7:36 pm
R u using timecode? Pioneer tends to have higher output.. Try using the modified timecode cd...
http://www.virtualdj.com/addons/view.html?type=tool
and make sure it is put to line in not phono at the herc mk2.. hopes that help:)
Posted Mon 06 Aug 07 @ 7:37 pm
haha andrew u so damn fast:)
Posted Mon 06 Aug 07 @ 7:38 pm
Hehe, that's what being unemployed during the summer months with no money or passport does to you. I'm supposed to be going on holiday in three weeks, I hope the postal strike doesn't delay my application otherwise I would have spent my entire summer living on here lol.
Posted Mon 06 Aug 07 @ 7:40 pm
lol.. good luck then:P
Posted Mon 06 Aug 07 @ 7:48 pm
i am using time code cds, i am burning a new one with the -13db now, but it was not getting the timecode signal.
Posted Mon 06 Aug 07 @ 7:52 pm
do u select line-in or phono at the back panel of the herc? switch it to line in n then at vdj timecoded input setting choose auto config..
Posted Mon 06 Aug 07 @ 7:56 pm
@chrisbo
Think u sort that aite:) njoy..n keep spinning:)
Posted Mon 06 Aug 07 @ 8:56 pm
Right guys...now i have a new problem. Im using the 4.3 demo version and have set it up with the external mixer. I have tried both the new and old drivers of the MK2 and still im getting the same issue. The settings i am using are: Input - None / Output - Ext Mixer / Sound card - Hercules MK2 and Channel settings are 1/2 Right 3/4 Left. The problem i am now facing are the headphones. When i plug them either in the MK2 console or the Ext Mixer i can only pre listen to deck b whilst mixing (and throught ext mixer the volume is very low). This is a problem because as you all know, you cant mix live without using headphone's.......
Posted Wed 08 Aug 07 @ 1:47 pm
