I'm using total control with cue and when using the jog wheel to scratch, there is a horrible lag. anyone having this same problem?
Posted Mon 23 Jul 07 @ 2:14 am
do you mean virtual vinyl or the total control controler
dont forget to add the console serial to your profile
what mac do you own
aslo try setting on performances , on options autolatency , and fastest
untick safe mode
what mac do you own
untick safe mode
Posted Mon 23 Jul 07 @ 2:26 am
i have virtual vinyl but im using total control..i'll get that s/n tonight when i get to the bar. when im playing a song and i reverse the the jog wheel, the song hesitates before continueing...i'll try those settings.
Posted Mon 23 Jul 07 @ 2:31 am
total control does NOT have touch sensitive jogwheels (meaning it will stop the song and stay stopped as long as you have a finger on it, like turntables or for example Pioneer CDJ800 players does).
For this reason, the Total Control can only be used for basic scratching, and not advanced scratches.
If you are a serious scratch dj, you need to use something that has touch sensitive jogwheels, either by timecode (using real turntables or CD decks that has this feature), or controllers that has this (Vestax VCI-100, XP10)
hope that helps
Posted Tue 24 Jul 07 @ 6:33 pm
