It is the skin.
Posted Tue 06 Nov 07 @ 10:01 pm
Sweet, thanks
Posted Wed 07 Nov 07 @ 12:38 am
UGH!!! OK so I have been waiting FOREVER for this skin.. now it's finally here and I get the error mentioned a few times a couple posts back...
"Invalid skin file (error line 0 in the xml)"
OK so in an attempt to fix it myself this is what I have done
1) Upgraded from rev4 to rev5
2) Downloaded and Installed the skin file again
3) Rebooted my computer
I launch Virtual Vinyl and I STILL get the same error. So I am guessing maybe it is either that
A) I have Virtual Vinyl NOT Virtual DJ or
B) Possibly is has something to do with running the Vista OS?
PLEASE can someone help????
Thanks
Thanks
Posted Wed 07 Nov 07 @ 5:01 am
Download the Skin file save it to your HD .....copy it to your My Documents/Virtual Vinyl/Skins.... using 7 ZiP open it up....try again....see if that works.
BTW Great looking Skin Format!! I love it so far cant wait for the final version!!!
Posted Wed 07 Nov 07 @ 5:31 am
TearEmUp.. no that didn't work :-(
However I was messing around with the files in the ZIP archive and replaced the 2.0 xml file with the 1.3 xml file and I was able to launch the 2.0 skin.
The skin looks great til I attempt to use it HaHa then when I mouseover certain aspects of the skin I see the old 1.3 stuff
I also tried opening up the xml file in Dreamweaver to see if I could maybe just edit line 0 but there is NO line 0.. it begins at 1
How can there be an error in line 0 if there is no line 0???
Posted Wed 07 Nov 07 @ 5:41 am
When will 2.1 be available for others to use/test?
I DJ a good deal and would be a good candidate.
My only suggestion would be buttons to select cross fader selection like in Mixstation.
Posted Wed 07 Nov 07 @ 1:19 pm
WOW FORMAT! Great great great and great! Your skin is so powerfull for me because i use VTC and mix Videoclips.
Keep going again.
Happy
Keep going again.
Happy
Posted Wed 07 Nov 07 @ 1:42 pm
Thanks
Thanks
I was this error message after resized the skin... have you try to reseize it ?
Posted Wed 07 Nov 07 @ 1:43 pm
Hi :)
nice job ....good :)
Nonno...
Nonno...
Posted Wed 07 Nov 07 @ 2:43 pm
oh yes, terrific and great job...
Posted Wed 07 Nov 07 @ 2:51 pm
I think you can renamed it version 2.5 instead of 2.1 with all the good job that you do on the skin ;-)
Posted Wed 07 Nov 07 @ 3:45 pm
Nah.. no luck on resizing the skin either...
anyone else have this problem but manage to fix it??
Posted Wed 07 Nov 07 @ 6:33 pm
Like always good work !!!!!!
Posted Wed 07 Nov 07 @ 7:33 pm
great work as usual
when will 2.1 be available please, as yet cant see it in pluggin section...thanks
Tayla
Tayla
Posted Fri 09 Nov 07 @ 9:07 am
I Vote for this skin of default for VDJ 5.1 !!!!!
Posted Fri 09 Nov 07 @ 2:47 pm
OK I kinda got it working.. in the OLD 1.3 xml file.. lines 13 thru 16 look like this:
<logo>
<size width="36" height="18"></size>
<pos x="24" y="5"></pos>
</logo>
but in the NEW 2.0 xml file.. lines 13 thru 16 look like this:
<logo>
<pos x="32" y="10"></pos>
</logo>
So what I did was change the NEW 2.0 xml file line 14 to match that of the OLD 1.3 xml file line 14.
I am now about to launch and use the 2.0 skin but take a look at how the logo kinda overlaps where it should not :-(
Any ideas how to fix?
<logo>
</logo>
<logo>
</logo>
Posted Sat 10 Nov 07 @ 1:08 am
OK Set the logo to
<logo>
<pos x="0" y="10"></pos>
</logo>
<logo>
</logo>
Posted Sat 10 Nov 07 @ 1:26 am
Format.. thanks brotha.. not quite as clean as the way it was designed for DJ but it works. I tried to change the values for the width and height to make it look nicer but then I ended up with an error on line 13 so I guess I'll leave well enough alone :-)
Thanks again for the skin dude.. AWESOME work!!!
Posted Sat 10 Nov 07 @ 2:04 am
Ok the logo in Virtual Vinyl is big er that in VDJ . I will see wot i can do for Mix Lab 3.0
The logo in Virtual Vinyl is ???
Posted Sat 10 Nov 07 @ 3:28 am
DJ FORMAT wrote :
Updated Graphics For Mix Lab 3.0
Video 1
Video 2
Video 1
Video 2
Posted Sat 10 Nov 07 @ 11:20 pm
