Hello
So i have bought a dj console mk2 with software virtual dj. Now i installed the software and the drivers and i put the usb in my pc and it works the scratching and all but i have no sound?
Thats realy weerd. I don't do anything wrong i hope i just connect the usb to my pc and thats all?
Can somebody tell me what i am doing wrong?
Thanks in advance.
Thanks in advance.
Posted Mon 16 Jul 07 @ 12:14 pm
have you applied your settings in sound options?
Tayla
Tayla
Posted Mon 16 Jul 07 @ 12:16 pm
do u connect the rca/minjack from ur console output to ur pc/2nd soundcard too, or amp or speaker?R u using the djc edition or trial pro?
Posted Mon 16 Jul 07 @ 2:02 pm
I bought a Mark 2 a couple of months ago - it has taken it upon itself to go funny - I plug it in, all the lights come on, the computer says "USB device not recognised" and it freezes. It even corrupted my database!
I tried everything I could think of, short of a full factory reset.
Sending it back isn't an option - firstly, I bought it online and secondly, I'm moving house.
Posted Tue 17 Jul 07 @ 3:59 pm
sounds like the firmwares currupt use the hardware reset as detailed here
https://virtualdj.com/forums/68291/Hardware_Technical_Support/Some_general_info_about_Hercules_DJ_Console_MK2.html
Posted Tue 17 Jul 07 @ 9:23 pm
