G'day,
if i choose to "upgrade" to VDJ would I have many problems running it....I have a P2.0ghz processor, 256mb ram with a 40gb hdd and run very little in the background.
Also, what tools are available to ease the transistion between programs?
Thanks in advance....I have oh so little time to access the internet(at work) otherwise I would look through the forum for my answers.
Cheers
Liam
Cheers
Liam
Posted Wed 09 Jul 03 @ 7:00 pm
same pc spec as mine and mine runs perfectly!
Posted Wed 09 Jul 03 @ 7:06 pm
Hi Walkers,
Thanks for your prompt reply, just afore I leave work.....appreciated.
later,
Liam
later,
Liam
Posted Wed 09 Jul 03 @ 7:26 pm
You can try it first and then see the results..
Posted Wed 09 Jul 03 @ 8:51 pm
